TimD5000
Aug 22, 2019Aspirant
RBK23 connecting to NBN Arris not working
Hi I am trying to connect a new Orbi Netgear router to the NBN arris box. My service provider is internode and it looks like they only want to support a few router brands of their choice. Is it p...
Aug 26, 2019Guru - Experienced User
I always presume that NG information is most accurate.
DMs are always DSL Modems. Modems only. D series is modem/router units.
michaelkenward
- FURRYe38Aug 26, 2019Guru - Experienced User
- michaelkenwardAug 26, 2019Guru - Experienced User
I have no idea what point you are trying to make.
The DM200 is a DSL modem with built-in router features that you have to disable if you want to use it with a router. That has confused several users in the past.
Been there. Done that.
Why not just go off an harass some more Netgear people? I am sure they appreciate it.
- TimD5000Aug 26, 2019Aspirant
Thanks Michael
Not trying to harrass. I think you take my posts out of context.
Anyways. Hope this is solved.
Good Luck. - TimD5000Aug 26, 2019Aspirant
Thankyou for your help
Yes managed to sort out with a firmware update
Good to hear. Thanks for letting us know.
I would make a back up configuration of the router to file for safe keeping.
Enjoy. :smileywink:
