themumbler8
Dec 08, 2019Aspirant
RBK23 Ethernet Back Haul VS RBK53
I am looking to get a Orbi System for my new home and had a couple of questions regarding the performance of Different Orbi models. Would the RBK23 with a wired back haul perform the same as a R...
- Dec 08, 2019
themumbler8 wrote:Would the RBK23 with a wired back haul perform the same as a RBK53?
If I add a RBS20 via Ethernet Back Haul to a RBK53 system would i see a loss in performance?
You won't lose performance with wired backhaul. Think of wireless backhaul as a poor man wired backhaul. Gig-Ethernet backhaul will always perform better than wireless backhaul. Given fronthaul is same for all, you're all set. Good luck!
themumbler8
Dec 09, 2019Aspirant
Thanks for the reply.
Would you say RBK23 setup with a eathernet back haul would perform the same as a RBK53?
SW_
Dec 09, 2019Prodigy
themumbler8 wrote:Thanks for the reply.
I would think so because both models have the same fronthaul and Quad-Core 710MHz processor. The performance difference between them is their respective wireless backhaul. Since your setup is Gig-Ethernet backhaul, they're aslo same.
