hbsiii
May 11, 2020Initiate
RBK23 limiting access to internet
I am finding after turning off the ATT Uverse wifi, the ORBI wifi is very good but when I try to go certain websites it as for a login and pw. nikonrumors.com for example. I don't have a login/pw for...
- May 11, 2020
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? IF this has a built in router, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopI would try option #2 first if the modem doesn't support full bridging. Easiest option would be #3 with Orbi.
