Monty33's avatar
Monty33
RBK23 not connecting to TV or Orbi APP
I've just run through the setup for the RBK23 with one router and two satellites.  It seems to be functioning perfectly on most devices, phones, pads etc.    The Orbi APP though continues to say "O...
  • Monty33's avatar
    Monty33
    Sep 20, 2021
    Thanks for the reply but I seem to have resolved it by turning off the wifi signal from the ISP router.
