DeividN1
Mar 30, 2021Tutor
RBK23 upload speeds in Router mode
Hi there, Why Netgear mesh systems (like my RBK23) limits dramatically the upload speeds setting up as Router? if I use the system as AP, all works perfect, but in Router mode... I can't obtain ...
Mar 30, 2021Guru - Experienced User
Make sure qos, traffic monitoring, parental controls, and access controls are disabled and reboot the router. those can sometimes decrease speeds.
- DeividN1Mar 30, 2021Tutor
Thx for your reply, all this services are disabled, but how can I check if QoS is off? I've read in some site that QoS is default off, it's true?
