DeividN1
Mar 30, 2021Tutor
RBK23 upload speeds in Router mode
Hi there, Why Netgear mesh systems (like my RBK23) limits dramatically the upload speeds setting up as Router? if I use the system as AP, all works perfect, but in Router mode... I can't obtain ...
Mar 30, 2021Guru - Experienced User
What modem/gateway is it connected to? are you running in a double nat?
https://kb.netgear.com/30186/What-is-Double-NAT
- DeividN1Mar 30, 2021Tutor
The ISP modem, is a HGU from Movistar/O2, the typical Mitrastar mounted by this corp like this one:
The modem is in bridge mode and all weight of network is over the Orbi RBR, I have single NAT.
- plemansMar 30, 2021Guru - Experienced User
Photos have to be approved by a moderator.
And it wouldn't be the first time an ISP supplied device didn't have a properly functioning bridge mode/passthrough mode.
Oh, sorry, I didnt konw.
It would be, but I've see this router (and same ISP) bridged working well with another systems.
Anyway, it's very strange, because when I setup the system for first time, I have the complete bandwith, but If I reboot the router, in this moment I start to have slow up speeds... And allways with a specific speed, without fluctuations.
