DeividN1
Mar 30, 2021Tutor
RBK23 upload speeds in Router mode
Hi there, Why Netgear mesh systems (like my RBK23) limits dramatically the upload speeds setting up as Router? if I use the system as AP, all works perfect, but in Router mode... I can't obtain ...
Apr 07, 2021Guru - Experienced User
Did you try it with the moviestar in router mode and the netgear in access point mode?
DeividN1
Apr 07, 2021Tutor
Yes, I have had it in AP mode and works fine. I’ve search info about this problem, and I find something very interesting... Movistar can’t warranty speeds over ppoe in bridged mode, and I think that the problem is the HGU router. I’ve bought an neutral ONT Ubiquiti for remove HGU. I will receive it tomorrow, when I test it, I will report the results here. Thanks!!!
