ricodafool
Apr 04, 2020Aspirant
RBK23 won’t connect to internet.
Hi, I recently purchased a RBK23 Orbi mesh. My ISP is Optus. Problem is that it won’t connect to internet, either via WIFI or using username and password. I’ve tried a million times, but to no avai...
Apr 07, 2020Guru - Experienced User
What is the Mfr and model# of the ISP modem/ONT the NG router is connected too? Any built in router here by chance? If so,
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Be sure to power OFF the ISP modem and RBR for 1 minute then back on with the modem. Power ON the RBR. Factory reset the RBR by pressing the back reset button for 15 seconds then release. Connect 1 wired PC to the back up the RBR and walk thru the setup wizard in a web browser at 192.168.1.1.
ricodafool
Apr 08, 2020Aspirant
Thanks, but I’m not sure if that’s the problem. I have NBN and then a Sagemcom modem. No other router. There’s no problem with internet in the room where the modem is, but for some reason the Orbi just wont connect to the Internet. I’ve tried the Advanced settings, but it didn’t recognise the PPPOE login details that I entered. Getting pretty frustrated, as spent a lot of money, but just can’t get it to work. I’ve tried calling Optus (and after waiting 90mins) they said no dropouts and Internet is fine, but they’ll call me back.
- Retired_MemberApr 08, 2020
ricodafool wrote:
Thanks, but I’m not sure if that’s the problem. I have NBN and then a Sagemcom modem. No other router. There’s no problem with internet in the room where the modem is, but for some reason the Orbi just wont connect to the Internet. I’ve tried the Advanced settings, but it didn’t recognise the PPPOE login details that I entered. Getting pretty frustrated, as spent a lot of money, but just can’t get it to work. I’ve tried calling Optus (and after waiting 90mins) they said no dropouts and Internet is fine, but they’ll call me back.Does your sagemcom modem have a router built in?
- ricodafoolApr 08, 2020AspirantYes, I it’s a combined modem/router.
https://devicehelp.optus.com.au/sagemcom/gateway-f-st-3864-mac-os-sierra/
I’ve also got an NBN connection box, with Ethernet cable to the modem/router.- FURRYe38Apr 08, 2020Guru - Experienced User
Try option #3 if you can't seem to get PPPoE working...
Be sure your PPPoE settings and input values are correct.
Does your ISP required PPPoE on the router or just the modem? If only the modem then you don't need PPPoE on the RBR. Use DHCP.
I would contact your ISP and have them help you ensure your modem is setup correctly and find out where PPPoE needs to be at.
ricodafool wrote:
Thanks, but I’m not sure if that’s the problem. I have NBN and then a Sagemcom modem. No other router. There’s no problem with internet in the room where the modem is, but for some reason the Orbi just wont connect to the Internet. I’ve tried the Advanced settings, but it didn’t recognise the PPPOE login details that I entered. Getting pretty frustrated, as spent a lot of money, but just can’t get it to work. I’ve tried calling Optus (and after waiting 90mins) they said no dropouts and Internet is fine, but they’ll call me back.- ricodafoolApr 08, 2020AspirantI have an NBN connection box and then this combined modem/router
I used the ppoe login details on bottom of modem, but it didn’t recognise them.
I’ll try and call my ISP again to confirm all the details.
