ricodafool
Apr 04, 2020Aspirant
RBK23 won’t connect to internet.
Hi, I recently purchased a RBK23 Orbi mesh. My ISP is Optus. Problem is that it won’t connect to internet, either via WIFI or using username and password. I’ve tried a million times, but to no avai...
ricodafool
Apr 08, 2020Aspirant
Thanks, but I’m not sure if that’s the problem. I have NBN and then a Sagemcom modem. No other router. There’s no problem with internet in the room where the modem is, but for some reason the Orbi just wont connect to the Internet. I’ve tried the Advanced settings, but it didn’t recognise the PPPOE login details that I entered. Getting pretty frustrated, as spent a lot of money, but just can’t get it to work. I’ve tried calling Optus (and after waiting 90mins) they said no dropouts and Internet is fine, but they’ll call me back.
Retired_Member
Apr 08, 2020
Does your sagemcom modem have a router built in?
- ricodafoolApr 08, 2020AspirantYes, I it’s a combined modem/router.
https://devicehelp.optus.com.au/sagemcom/gateway-f-st-3864-mac-os-sierra/
I’ve also got an NBN connection box, with Ethernet cable to the modem/router.- FURRYe38Apr 08, 2020Guru - Experienced User
Try option #3 if you can't seem to get PPPoE working...
