ricodafool
Apr 04, 2020Aspirant
RBK23 won’t connect to internet.
Hi, I recently purchased a RBK23 Orbi mesh. My ISP is Optus. Problem is that it won’t connect to internet, either via WIFI or using username and password. I’ve tried a million times, but to no avai...
ricodafool
Apr 08, 2020Aspirant
Yes, I it’s a combined modem/router.
https://devicehelp.optus.com.au/sagemcom/gateway-f-st-3864-mac-os-sierra/
I’ve also got an NBN connection box, with Ethernet cable to the modem/router.
Apr 08, 2020Guru - Experienced User
Try option #3 if you can't seem to get PPPoE working...
