LAZii
Sep 22, 2019Follower
RBK30 - RBW30 Disconnecting from router
First time using Netgear community and couldn't find any discussion similar to my issue. I purchased this RBK30 combo few months ago and the RBW30 satelite is playing up (was working fine previously), I had to power off the unit during electric work since then the satelite has issue connecting with the router. I had tried reseting it 8 times and I'm getting same results. I'm suspecting the radio module is faulty.
When I reset it and start sync/peer with the router, it will show poor connectivity even though they are only 2 metres apart, then eventually it will be in disconnected state and stays disconnected. Even if I was able to get it peered up, when i move the satelite to a room less than 10m away it cannot contact the router.
I know the router unit is working because all devices are connected to it and working.
I don't want to try updating the firmware on the satelite because it might disconnect during the process and corrupt.
I've contacted the store to see if I can get a replacement satelite but in the meantime I want to know if anyone else had this issue.
1 Reply
I would get a replacement RBW.
30 feet is recommended in between RBR and RBW to begin with depending upon building materials when wirelessly connected.
LAZii wrote:First time using Netgear community and couldn't find any discussion similar to my issue. I purchased this RBK30 combo few months ago and the RBW30 satelite is playing up (was working fine previously), I had to power off the unit during electric work since then the satelite has issue connecting with the router. I had tried reseting it 8 times and I'm getting same results. I'm suspecting the radio module is faulty.
