penguinknot
Sep 17, 2018Follower
RBK30 - Very fast when connected to satellite but very slow when connected to main router
I have 100mbps from my cable provider. I have the RBK30 with an additional satellite so two satellites (all have the confirmed latest firmware). One satellite is in the living room and the other is i...
Sep 17, 2018Guru - Experienced User
What FW is currently loaded?
What is the Mfr and model# of the IP modem the Orbi is connected too?
What Speeds UP and Down do you pay for?
What are ethernet speeds with a wired PC?
What devices are you testing with? Try different devices as well.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
