atomarchio
Jun 06, 2020Tutor
RBK30 disconnecting
So I've owned the RBK30 for 2 years now and it's not working properly.
I've had to reboot the router each morning 3 of the past 4 days as all of my devices are no longer connected to the internet when I wake up.
Once I reboot the device things work fine but I have to do this almost daily.
Is there anything I can try to resolve the problem? Or is it just time to buy a new router?
Please help. Thanks.
1 Reply
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?What is the size of your home? Sq Ft?
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
https://kb.netgear.com/19668/Link-Rate-and-Transfer-SpeedTry enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
