sank22's avatar
sank22
Follower
Feb 19, 2018
RBK30 satalite
Does the satalite give off the same signal strength as the base station.  I have the base station in the basement so that I can hardwire a few devices.  The satalite is upstairs in the center of the house.  If I wanted to get better signal outside do both satalite and base station give off the same signal strength?  Or should I have the base station upstairs and satalite downstairs?
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    No the RBK30 has a smaller range than the main router which is either a RBR50 or 40.
    DarrenM
