Mike3963
Aug 29, 2021Aspirant
RBK33 benefit of adding ethernet satellite RBS50
Bought RBK33 system one year ago (RBR40 router, two RBW30 satellites). Noted the satellites do not have ethernet ports. My work laptop is connected to satellite via WiFi. My VPN connection to work...
Aug 29, 2021Guru - Experienced User
Possibly.
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
One can add a RBS20, or RBS40v as well.
Mike3963
Thanks.
current satellite RBW30 just updated firmware to 2.6.2.2. Satellite is about 50 ft away from router. Satellite is about 15 ft away from laptop. Home is ~2300 sq ft.
Laptop is connected at 5GHz but setting is auto.
ISP is Spectrum. Modem is Technicolor E31T2V1 which is DOCSIS 3.1 compatible.
- FURRYe38Aug 29, 2021Guru - Experienced User
You might try RBW a bit closer to the RBR. Maybe 40feet and see if this helps any...
- Mike3963Aug 29, 2021Aspirant
would anybody know if adding RBS20 or RBS40 with ethernet cable from satellite to nearby laptop would be better and more stable than wifi from existing satellite? And is RBS20/40 a better match since the base router is AC2200 not AC3000?
- plemansAug 30, 2021Guru - Experienced User
Before trying that, why not hardwire your pc/laptop into the router and see if its stable with your vpn?
If that is the only device with issues, I'd check to ensure hardwiring helps before investing in another satellite that we can't 100% say will help.
