bg12345
Nov 10, 2018Aspirant
RBK33 extended using RBS50 ?
I have the RBK33 system, with an AC2200 router and two of the smaller wall plug-in satellites. I'd like to add wired Ethernet backhaul.
Can I purchase the RBS50 (AC3000) as an extender and co...
- Nov 11, 2018
I believe you can use either of them since you will use Ethernet Backhaul. I doubt that RBS50 will work properly with RBR40 if you will use wireless backhaul, so I would avoid adding RBS50 satellite to RBR40 router.
As mentioned earlier, I see no reason for you to get the RBS50 satellite since you have RBR40 router as you will not get out the best out that satellite (wireless backhaul capability of the RBS50 will only be useable together with RBR50 router).
I recommend that you get RBS40 (Option A) or RBS20 to connect to your RBR40. RBS40 is the same as RBS20 but with more ethernet ports (same number of ethernet ports as in RBS50).
bg12345
Nov 11, 2018Aspirant
Let me clarify, in case I didn't specify this properly. I own the following:
I would like to add an extender via **wired Ethernet**. Which extender should I purchase?
Option A: NETGEAR Orbi RBS40 Wireless Range Extender
Option B: NETGEAR Orbi Ultra-Performance Whole Home Mesh WiFi Satellite Extender AC3000 (RBS50)
I have a fairly long home, and I want to place the extender on the second floor above the router and then I'll place my existing smaller satellites to cover the remaining area.
Thank you!
- ekhalilNov 11, 2018Master
- bg12345Nov 11, 2018Aspirant
Thanks, ekhalil. That is helpful. One remaining question: if I purchase the RBK23 (one RBS20 router and two RBS20 extenders), is there a way to configure the router to work as an extender? Or would it basically be useless given my existing router?
Part of the reason I ask is that it's hard to find a single RBS20 extender for sale and the price of an RBS40 is only $50 cheaper than getting the RBK23 three-pack.
Thank you.
- ekhalilNov 11, 2018MasterIt’s unfortunately not possible to use the RBR20 router as a satellite.
- FURRYe38Nov 11, 2018Guru - Experienced User
I concur, try the RBS40.
