craig83
Aug 02, 2019Aspirant
RBK33 Not updating IOS apps
I recently installed the RBK33 Orbi with satelites. Connected great and getting good speed and coverage. However, apps are not updating and when trying to install new ios apps they do not download. ...
- Aug 02, 2019
I would try using a different dns provider than the one your isp uses if you have that selected within the orbi setup. you can try the google dns servers at 8.8.8.8 or 8.8.4.4
see if this helps.
Aug 02, 2019Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
Do other internet apps work?
- craig83Aug 02, 2019Aspirant
Netgear Cable Modem CM500
I am not sure which mode it is in. Just did a norml install. I have not messed with any of its settings (Orbi)
- plemansAug 02, 2019Guru - Experienced User
see if this helps.
- FURRYe38Aug 02, 2019Guru - Experienced User
Ok, Checking the modem for any built in router here. Your ok here.
Try changing the DNS on the RBR as suggested.
What exactly does changing the DNS do? Sorry, am not smart when it comes to this? Can this be done through the Orbi app?
