craig83
Aug 02, 2019Aspirant
RBK33 Not updating IOS apps
I recently installed the RBK33 Orbi with satelites. Connected great and getting good speed and coverage. However, apps are not updating and when trying to install new ios apps they do not download. ...
- Aug 02, 2019
I would try using a different dns provider than the one your isp uses if you have that selected within the orbi setup. you can try the google dns servers at 8.8.8.8 or 8.8.4.4
see if this helps.
craig83
Netgear Cable Modem CM500
I am not sure which mode it is in. Just did a norml install. I have not messed with any of its settings (Orbi)
Aug 02, 2019Guru - Experienced User
see if this helps.
