PawelZawadzkiPL's avatar
Aug 26, 2021
RBK352 satellite synch issue.
Dear Community,  I have encountered installing new Orbi RBK352. For some reasons I cannot synchronize satellite once it's relocated into seperate floor. What's very strange is:
1) any personal device I have (IPhone or HP laptop) wery well detecting signal from master router (located floor above).
2) signal range brodcasted from master router is detected as strong by these personal devices. It's around 70 % strong.
3) Speed performance measured on 2nd floor or ground floor (master router is placed in 1st floor) are very good. Actually with ISP link capacity offered by provider.
4) Firmware ver installed: 4.3.4.8
Im summary - what I have observer is for some reason stetelite cannot detect master router even when other devices can.
Did anyone from Community encountered such case ? Any tips, fixes or suggestion ?
PS. If I can share more testing results or config to understand issue better I'm here to help.
Thank you :)
1 Reply
  • FURRYe38's avatar
    Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
    https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
    Thank you.
