BdgrKM
Aug 26, 2020Aspirant
RBK40 — Orbi AC2200 Tri-band WiFi System - Drops WiFi Constantly
Hello, all. I am currently using a RBK40 — Orbi AC2200 Tri-band WiFi System connected directly to my Frontier (nee, Verizon) FiOS ONT that is mounted on the exterior of my house in a weather protect...
BdgrKM
I'll try it. I just updated the Firmware on Sunday night. I didn't realize that Orbi would download something that was not the "official" firmware ...
Mstrbig
Aug 26, 2020Master
BdgrKM wrote:I'll try it. I just updated the Firmware on Sunday night. I didn't realize that Orbi would download something that was not the "official" firmware ...
It appears that depending on what version firmware is on the router and satellites, different versions are getting pushed to the system. My RBK53 system was on a previous firmware and updated to 2.5.1.16. Since then, several users have reported newer firmware automatically getting updated, but my system shows no new updates and the NG wesite still shows 2.5.1.16 as the current firmware.
- BdgrKMAug 26, 2020Aspirant
Very interesting. I just changed 2.4Ghz to channel 8 (using NetSpot I saw that it was a totally unused channel around me) and turned off the 20/40 Coexistence ... I will monitor it over the next few days.
Suffice it to say, my son was none to happy when he missed out on his "song" during Kindergarten today, so any improvement is good enough for me!
- BdgrKMAug 27, 2020Aspirant
So I changed the channel for 2.4 ... it crapped out at about 8:30PM last night (about two hours after I made the change), but since then has been up and running. I'll keep monitoring it for a couple of days. If it fails again, I'm thinking that I'll just end up getting a different system, because I'm not as adept as most on here about fiddling with a system that is supposed to be plug and play .... and I can't risk the downtime necessary to test and fiddle all the time ...
- FURRYe38Aug 27, 2020Guru - Experienced User
Try a factory reset on the RBR and RBS and setup from scratch since the FW was updated.
30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
Any Wifi Neighbors near by? If so, how many?One User Experience/Configuration:
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
BdgrKM wrote:So I changed the channel for 2.4 ... it crapped out at about 8:30PM last night (about two hours after I made the change), but since then has been up and running. I'll keep monitoring it for a couple of days. If it fails again, I'm thinking that I'll just end up getting a different system, because I'm not as adept as most on here about fiddling with a system that is supposed to be plug and play .... and I can't risk the downtime necessary to test and fiddle all the time ...
