BdgrKM
Aug 26, 2020Aspirant
RBK40 — Orbi AC2200 Tri-band WiFi System - Drops WiFi Constantly
Hello, all. I am currently using a RBK40 — Orbi AC2200 Tri-band WiFi System connected directly to my Frontier (nee, Verizon) FiOS ONT that is mounted on the exterior of my house in a weather protect...
BdgrKM
Aug 27, 2020Aspirant
So I changed the channel for 2.4 ... it crapped out at about 8:30PM last night (about two hours after I made the change), but since then has been up and running. I'll keep monitoring it for a couple of days. If it fails again, I'm thinking that I'll just end up getting a different system, because I'm not as adept as most on here about fiddling with a system that is supposed to be plug and play .... and I can't risk the downtime necessary to test and fiddle all the time ...
Aug 27, 2020Guru - Experienced User
Try a factory reset on the RBR and RBS and setup from scratch since the FW was updated.
30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
BdgrKM wrote:So I changed the channel for 2.4 ... it crapped out at about 8:30PM last night (about two hours after I made the change), but since then has been up and running. I'll keep monitoring it for a couple of days. If it fails again, I'm thinking that I'll just end up getting a different system, because I'm not as adept as most on here about fiddling with a system that is supposed to be plug and play .... and I can't risk the downtime necessary to test and fiddle all the time ...
- BdgrKMAug 28, 2020Aspirant
I did the Factory Reset last night. A few hours later WiFi dropped again, but came back on (I can see when my cameras send me an email that they disconnected and when they come back online). So far it's been up for the entire morning ... we'll see how it goes. I was reading about how to do a Firmware Downgrade, but where would I find the older firmware to do that?
- MstrbigAug 28, 2020Master
BdgrKM wrote:I did the Factory Reset last night. A few hours later WiFi dropped again, but came back on (I can see when my cameras send me an email that they disconnected and when they come back online). So far it's been up for the entire morning ... we'll see how it goes. I was reading about how to do a Firmware Downgrade, but where would I find the older firmware to do that?
Are you seeing the camedras go down and assume the entire WIFI is dead, or are you not able to get access with any WIFI device?
I ask this because cameras dropping WIFI is common until you force the camera to connect to the closest Orbi node.
We're seeing the entire WiFi go down -- no devices can access it. I just get my notifications from the Cameras, so I know it happened when I'm sleeping! When we're awake, we see that all of the WiFi just stops working -- no matter if the device is attached to the Router or the Satellite, but our hardwired to the router devices still work on the 'net.
