BdgrKM
Aug 26, 2020Aspirant
RBK40 — Orbi AC2200 Tri-band WiFi System - Drops WiFi Constantly
Hello, all. I am currently using a RBK40 — Orbi AC2200 Tri-band WiFi System connected directly to my Frontier (nee, Verizon) FiOS ONT that is mounted on the exterior of my house in a weather protect...
BdgrKM
Aug 28, 2020Aspirant
I did the Factory Reset last night. A few hours later WiFi dropped again, but came back on (I can see when my cameras send me an email that they disconnected and when they come back online). So far it's been up for the entire morning ... we'll see how it goes. I was reading about how to do a Firmware Downgrade, but where would I find the older firmware to do that?
Mstrbig
Aug 28, 2020Master
BdgrKM wrote:I did the Factory Reset last night. A few hours later WiFi dropped again, but came back on (I can see when my cameras send me an email that they disconnected and when they come back online). So far it's been up for the entire morning ... we'll see how it goes. I was reading about how to do a Firmware Downgrade, but where would I find the older firmware to do that?
Are you seeing the camedras go down and assume the entire WIFI is dead, or are you not able to get access with any WIFI device?
I ask this because cameras dropping WIFI is common until you force the camera to connect to the closest Orbi node.
- BdgrKMAug 28, 2020Aspirant
We're seeing the entire WiFi go down -- no devices can access it. I just get my notifications from the Cameras, so I know it happened when I'm sleeping! When we're awake, we see that all of the WiFi just stops working -- no matter if the device is attached to the Router or the Satellite, but our hardwired to the router devices still work on the 'net.
- FURRYe38Aug 28, 2020Guru - Experienced User
You can downgrade to v16 on the RBS first then RBR lastly. Try this and then see. Try a set again if v16 continues to experience problems.
Try some of the suggestions in the user stability link.
Thanks! But where do I find the v16 firmware?
I did all of the stuff from the stability link except for downgrading the firmware ...
