Liamhereuk
Jun 22, 2020Aspirant
RBK40 — Orbi AC2200 Tri-band WiFi System and adding a satellite (latest model)
had my system running 2 years no problems and moved to a bigger older house with 1.5 foot stone walls as this model no longer is made what can i use for a 2nd satelilite/ will the newer models conn...
- Jun 22, 2020
Any RBS50, RBS50Y, RBW30 or RBS20 will do.
Liamhereuk
if i have a 3nd satellite it will work all over the house.... tested my moving 2nd into where the 3nd would go
just need the 3nd and not sure if the latest model will work with my orbi system
Jun 22, 2020Guru - Experienced User
