Zoliver
May 30, 2018Tutor
RBK40 - no connectivity
After just a short 48 hours with the Orbi, I'm regretting my purchase. I work from home and have lost my connection 3 times yesterdat, but it reconnected fairly quickly. Today, My connection dropped and I can't get reconnected. Anyone have any ideas before I box this system back up?
What connect are you loosing? Wireless or wired? No internet?
Do you have access to the routers web page when you get no connectivity?
What FW is currently loaded on it?
What is the Mfr and model# of the ISP modem its' connected too?
Any wifi nieghbors near by? If so, how many?
Try using manual channel 1, 6 or 11 on 2.4Ghz.
Try disabling MIMO, Daisy Chain and Fast roaming.
- ZoliverTutor
I'm losing my wireless connection. The one wired connection seems to not have issues, but the sattelite isn't in my office because it has to be close to the front door for our ring doorbell to work.
I downloaded the most recent FW that was available when I set-up. And I'm connected to an Xfinity modem.
Several neighbors are wireless, but I'm a secured network with no guest access available. I'm not sure how to switch channels on the Orbi and am assuming I have the 2.4Ghz available to me.
Try using manual channel 1, 6 or 11 on 2.4Ghz. Found under Basic/Wireless on the routers web page.
Try disabling MIMO, Daisy Chain and Fast roaming. Found under Advanced/Advanced Settings/Wireless.
What is the distance between the router and satellite?
So you have connectivity now?
- ZoliverTutor
Yes, I'm connected. I had to make another call to support. One of the sattelites wouldn't update so they walked me through how to force the update.
Things seem good right now. My fingers are crossed for tomorrow during the work day. I lost 2-1/2 hours today.
Let us know how it goes tomorrow.
:smileywink:
Sounds like you got it working. Enjoy.
:smileywink:
