rDozer
Sep 24, 2018Aspirant
RBK40 - Orbi rebooting at specific times throughout the day
Hey guys, I've been having issues with my Orbi system for awhile now and been trying to find fixes but nothing has worked. My router and satellite will reboot everyday at 9:46pm on the dot. I found a...
Sep 25, 2018Guru - Experienced User
What FW is currently loaded?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
- rDozerSep 25, 2018Aspirant
Furry I've posted a thread before and got the same exact response you just posted. I tried the things you recommended with no success. If you read my OP, I found what seemed to be a good solution but the download page is no longer there. Any information on that ?
- Christian_RSep 25, 2018NETGEAR Employee Retired
Hello rDozer,
The 2.1.2 is a previous beta firmware for the RBK50. If I'm not mistaken you have an RBK40, correct? Would you mind telling us what FW your Orbi's are currently on?
~Christian
On the netgear Orbi login page where I can access my settings, under firmware it says that I have RBS40 and RBR40, but I couldn't find those models on the dropdown menu when I did the original post. On that page though, it says that I have 2.1.4.16 firmware version for both devices.
