bb9394
Feb 15, 2019Aspirant
RBK40 AC2200 - Access Control Problem
I have turned "Access Control" ON, and have selected "Block all new devices from connecting". I have then started to entered some "allowed" devices' MAC address.
The software have accepted the...
Feb 15, 2019Guru - Experienced User
Have you set up IP address reservations for these devices your controlling?
Remove the control configurations. Then disable access controls.
Go in and setup IP address reservations for the devices your wanting to control first. Once this is done, then go back in and add these devices to the control configuration and see if the problem continues. There has been others posting about having Access Control problems on Orbi...
