Biigdaddio's avatar
Biigdaddio
RBK40 and Nighthawk for 2 wireless networks
I know this sounds crazy but I'm wondering if I can use an old Nighthawk router to provide one wireless network for a specific area but connect it to an Orbi for a second network to continue to serve...
  • CrimpOn's avatar
    Apr 19, 2020
    Biigdaddio wrote:
    Is that possible? What will be the downsides? (I know, make sure the two networks are on widely separated channels...) But will this work at all?
    Certainly it will work.  Thousands of customers purchase Orbi's and neglect to disable their ISP WiFi.  The key thing to remember is that devices will not "roam" from the Nighthawk WiFi to/from the Orbi WiFi.  As long as he gets a good signal from the Nighthawk, there should be no problem.
