Stimar
Oct 07, 2019Tutor
RBK40 black list external IPs
Hi All, I'm wondering is it possible to black list external IP addresses ? In my router logs i can see a lot of "failed login" attempts (in hundreds). I can stop the remote management funtion, but ...
Oct 07, 2019Guru - Experienced User
Most routers firewall are good enough to block problems like this. The logs are just reporting that the firewall is doing it's job.
Contact your ISP and have them help you change the WAN IP address that is given to you by your ISP.
Besure that respond to WAN pings is disabled.
Do you have Remote Management enabled on the RBR? If you don't need this, disable this feature.
Stimar
Oct 08, 2019Tutor
Hi All,
My Orbi FW is the lattest one, my IP is dynamic one. I'm haveing one small ISP router (which is spliting the internet and the TV) before Orbi on which i don't have access anyway.
I'm concerned about the DoS attack, the problem here is that someone is trying to brute force my password. That's why we can see so much failed login attempts and the goal here is to have remote access to my switch, but to be able to block external IPs.
- FURRYe38Oct 08, 2019Guru - Experienced User
Contact your ISP and have them help you change the WAN IP address that is given to you by your ISP. if you don't have access to there device, then they need to help you with this.
