RB37
Jun 02, 2017Aspirant
RBK40 Coverage
On the US website (https://www.netgear.com/orbi/rbk40.aspx) it is claimed that the RBK40 "covers up to 4,000 square feet with high performance AC2200 WiFi" and on the UK website (http://www.netgear.c...
RB37
That is my problem too. I'm in a 4 storey Edwardian house, just over 250 sq M, so 4000 sq ft should do me fine, but not sure which to buy now. in a plan view I only need 680 sq ft, but it's the vertical that's a problem for me
Is your primary unit in the middle floor? I'll be putting my primary on floor 2 and was thinking of the satelitte on floor 3, with hopefully coverage extending onto floors 1 and 4.
timch
Jun 02, 2017Luminary
Yes, that's how mine is but wifi can get a bit marginal at the very back of the house. Still it's a lot better than any other solution.
