Ryan1919
Sep 01, 2018Tutor
RBK40 Download Speed Slows Down After 5 Days
I have the RBK40 Router with two RBS20 satellites connected to my home wifi. I'm using it in router mode and not AP mode..Every 5 days my Internet speed drops from around 200mbps to around 40mbps..Th...
Sep 02, 2018Guru - Experienced User
What FW is currently loaded?
What is the Mfr and model# of the IP modem the Orbi is connected too?
What is the Mfr and model# of the ethernet switch if one is in the configuration.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Are your speeds tested wireless or wired?
Was a reset performed after the FW update?
Ryan1919 wrote:
I have the RBK40 Router with two RBS20 satellites connected to my home wifi. I'm using it in router mode and not AP mode..Every 5 days my Internet speed drops from around 200mbps to around 40mbps..The satellites are not affected and I still get over 200mbps on each satellite. My satellites are connected through wireless backhaul. I can reboot the the system and every thing will go back to normal for another 5 days..What could be causing this? Memory leak of some sort) I have not changed any of the default settings except for disabling the daisy chain option. I am running the latest firmware (2.1.4.16)
Ryan1919
Sep 02, 2018Tutor
On #4 I meant to say the speeds slow down on the 5th day every time and after i reboot the speeds will resume to over 200 mbps second again.
