Ryan1919
Sep 01, 2018Tutor
RBK40 Download Speed Slows Down After 5 Days
I have the RBK40 Router with two RBS20 satellites connected to my home wifi. I'm using it in router mode and not AP mode..Every 5 days my Internet speed drops from around 200mbps to around 40mbps..Th...
Ryan1919
Sep 02, 2018Tutor
Currently none of my neighbors are on the same channel as me..I will check again and see if anything has changed and if they are I will change the channel. Thanks for your help!!
Sep 02, 2018Guru - Experienced User
Try a factory reset as a last resort as well and set up from scratch. Disable MIMO, Daisy Chain and Fast Roaming as well...use manual channels...Hope something makes it better for you..
