Ryan1919
Sep 01, 2018Tutor
RBK40 Download Speed Slows Down After 5 Days
I have the RBK40 Router with two RBS20 satellites connected to my home wifi. I'm using it in router mode and not AP mode..Every 5 days my Internet speed drops from around 200mbps to around 40mbps..Th...
Sep 16, 2018Guru - Experienced User
Yes, lets do a factory reset on the router and set up from scratch. IF the problem continues after than then the router needs to be RMAd and replaced.
Ryan1919
Sep 17, 2018Tutor
I did a factory reset today so we will see if the problem persist after the 5th or 6th day. I will update on the 6th day. Thanks for your help!!
- FURRYe38Sep 18, 2018Guru - Experienced User
:smileywink:
- Ryan1919Sep 24, 2018Tutor
Just wanted to make a quick update on my situation ..I'm on the seventh day and my speeds are staying constant at 217mbps on the router and satellites. This is after I did a factory reset 7 days ago. I will keep watching it and checking the speeds everyday to see if it does it again. I didn't notice my speeds going down until the 20th day the first time it happened, but I wasn't testing it everyday so I don't know when it happened the first time..I will keep this thread updated.
- FURRYe38Sep 25, 2018Guru - Experienced User
Thanks for letting us know. Hope it keeps working well for you. Enjoy. :smileywink:
