YabbadabbaDoooo
Jun 28, 2017Apprentice
RBK40 Issues Resolved with latest firmware 1.11.0.20
I have the Orbi RBK40 with one satellite. I was experiencing the various issues described in other threads with instability. The signal would randomly drop, speeds fluctuated wildly from one second...
YabbadabbaDoooo
Jun 29, 2017Apprentice
DarrenM wrote:
Thank you for the feedback on the latest firmware that it did fix the issue that you are having.
Just to be clear, I posted this to see if other users have experienced resolution of the many stated problems this system has had since it was released. I had short windows of time when the system was stable after I made some minor changes to the Router, or as in this case, new firmware came out. Only to be disappointed after a week or so when the problems began again.
I do not want to return the product if this latest Firmware update truly fixed the problem but I can't wait too long if I am going to return it. I hoped others would post their experience on this thread to give me some reassurance that it is in fact permanently resolved. The majority of posts related to the Orbi seem to be related to the RBK50, which is to be expected since it has been on the market longer. I don't know how to get more visibility to this thread. Perhaps as a moderator you can help get more visibility on this thread.
Doug-48051
Jul 04, 2017Luminary
I have RBR50 setup and FW. I am getting drops of SAT through out the day, roughly 3 hours a part. Outages do seem short in nature.
- DarrenMJul 05, 2017Sr. NETGEAR Moderator
Hello Doug
Are you on the latest firmware or the beta firmware?
DarrenM
- Doug-48051Jul 06, 2017Luminary
The Admin pages reports FW 1.11.0.20 latest. Not Beta for the AC3000
- YabbadabbaDooooJul 17, 2017Apprentice
Doug (and Darren), the latest release of 1.12.0.18 "regressed" my system back to multiple problems that render it basically useless. I am going to roll back to 1.11.0.20 as I had 3 glorious weeks of complete stability and high speeds in all parts of my house. Can't be a coincidence...and, not sure why Netgear doesn't seem to connect the dots that the AC2200 (RBK40) and AC3000 (RBK50) firmware fixes for one seem to negatively affect the other. Release notes for 1.11.0.20 mentioned only the RBK40 issues. Likewise, 1.12.0.18 mentioned only the RBK50 issues. I will hopefully be able to report for others if my rollback works and I get back to stability. I am plugged directly into my cable modem with the Orbi off so I could download the firmware files. I started a new thread since I will go out on a limb and bet others have experienced the same thing. Though it appears the majority of people on these Forums have the AC3000 (RBK50) system so perhaps all is well for them and there won't be enough people that have the AC2200 (RBK40) to confer (or commisurate) with on this.
