rockyucm
May 16, 2019Aspirant
RBK40 Orbi connectivity issues (1000Mb)
My ISP provided 1000Mb service with Nokia G-240G-C Modem while my Netgear Orbi AC2200 RBK 40 ,updated with latest firmware, cannot get the DHCP connection. The internet service is fine as my D-Link ro...
- May 17, 2019The problem has been solved, ISP replied that the port was used by the original router and for 1000Mb connection, we need to turn off the modem half day or simply use another port of the modem
May 16, 2019Guru - Experienced User
Did you power OFF the modem for 30 seconds along with the RBR, then power on the modem first, then the RBR?
- rockyucmMay 17, 2019AspirantThe problem has been solved, ISP replied that the port was used by the original router and for 1000Mb connection, we need to turn off the modem half day or simply use another port of the modem
- FURRYe38May 17, 2019Guru - Experienced User
Glad you got it working. Enjoy. :smileywink:
