Sharknado3
Jun 19, 2019Aspirant
RBK40 Orbi connectivity issues (1000Mb)
Device had a white ring light on the satelite and is constantly dropping connection to no internet. The cable company has been out and verified the lines are correct. It has been working fine with...
Jun 19, 2019Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
- Sharknado3Jun 19, 2019AspirantIt is in router mode, probably 30 to 40 feet in distance apart.
No clue on the cable modem brand.
How is one supposed to replace a device under warranty if defective or Netgear refuses to let you talk to anyone? I'd like to hear that answer, but I will certainly see if I can walk my 70+ year in laws through these suggestions.- FURRYe38Jun 19, 2019Guru - Experienced User
Please find out the modem Mfr and model# if possible.
- Sharknado3Jun 19, 2019AspirantIt is a Calix Ont - optical network terminal as they have a fiber connection.
