Bob-Loblaw
May 10, 2020Follower
RBK40 (RBR40 & RBS40) - disable wifi broadcast on satellite?
Hi all- I have an RBK40, which is the RBR40 router, and RBS40 satellite. We just moved and I no longer have a need for the increased range the satellite offers. But I am using the satellite b...
CrimpOn
May 10, 2020Guru - Experienced User
Bob-Loblaw wrote:My question is, how can I prevent the satellite from broadcasting wifi, while still allowing the Ethernet port on it to work? Basically i want my hardwired desktop to be the only device that is connected to the satellite
Netgear does not provide a method to "turn off a radio". The entire point of the product is WiFi. There may be a "hack" using telnet to disable satellite radios. I have no personal knowledge of how to do it, or whether the hack survives a restart, after a power outage for example.
12 ft. is considered "too close" for a satellite. You might want to reduce the transmit power level on the Orbi system.
