keeper88
Apr 30, 2018Guide
RBK40 (RBR40& RBS40) DISCONNECTS - fixed before but auto firmware upgrades BREAK!!!
I had experienced TONS of disconnects, primarily iOS devices (they're pretty popular, you think?), and helped Netgear techs troubleshoot and tested beta firmware. Finally in August last year FW versi...
keeper88
May 01, 2018Guide
Thanks, maybe I'll give v2.3.1 a try, if I can get my hands on it. Even if that works, I still worry that the auto-update will bring out another poorly tested release thereafter to break it (as it did before), and I still see that as a big shortcoming by Netgear. I presume you had disconnect issues with Apple devices prior to installing v2.3.1.x beta, correct? They were hard to miss, if using iOS devices with any regularity...
May 01, 2018Guru - Experienced User
You can get v2.1.3.6 FW for your 40 series system here:
https://community.netgear.com/t5/Orbi/Orbi-MR-2-1-Update-3-23-18/m-p/1533584/highlight/true#M26234
I would do a full factory reset after loading the satellite first then update the router 2nd.
I have not experienced any issuses with my Apple devices since I got my system 3 months ago.
