Bestia
Aug 23, 2018Aspirant
RBK40 Slow Website on wifi, fast speedtest
Hey everyone,
im using the Orbi WiFi System for a few month now. Latetly my Orbi asked me to update the firmware which is now V2.1.4.16.
Im currently running the system without any satellites...
Aug 23, 2018Guru - Experienced User
What is the Mfr and model# of the IP modem the Orbi is connected too?
I would do a factory reset of the router since you updated and set up from scratch.
- BestiaAug 23, 2018Aspirant
Thanks for that fast answer. Actually I havent thought about doing a complete reset after the last update - which I just did now. I also set the Channels to 11 & 48
Sadly I got huge neighbour wifi traffic, see the screenshot below. Im connected to telekom speedport smart.
Ill monitor if the reset fixed my problem and get back to you later. Thanks so far
- FURRYe38Aug 23, 2018Guru - Experienced User
:smileywink:
