Specxlar
Mar 11, 2018Follower
Rbk40 still randomly dropping connection after new update
My system still drops connection every once and a while which is especially annoying when I’m playing online games. My Xbox one is wired to one of the satellites. When it works, it works great, but th...
Mar 12, 2018Guru - Experienced User
What is the Mfr and model# of your ISP modems? Any built in routers by chance?
Any wireless neighbors near by? If so, how many?
Try setting manual channel 1, 6 or 11 on 2.4Ghz. Any unused channel on 5Ghz.
Also try temporarily disabling Fast Roaming, Daisy Chaining, Beamforming and MIMO. Daisy chaining is only needed of you have two or more Satellites. Enable Beamforming and MIMO later on after checking the system out with out them being disabled. Restart both router and Satelllite after disabling any of these then test.
Specxlarwrote:
My system still drops connection every once and a while which is especially annoying when I’m playing online games. My Xbox one is wired to one of the satellites. When it works, it works great, but the drops are killing me. Anyone know of any fixes?
