keung006
Oct 03, 2018Aspirant
RBK40 upload movie on youtube by wifi
The youtube upload speed through is extremely slow, it takes 70minutes for 1GB movie. But the speed test shows that the upload speed is 65Mb/s.
But when I use 4G mobile network to upload the same ...
Oct 03, 2018Guru - Experienced User
What wireless device are you using to upload the file?
Which frequency is the device connected too? if 2.4ghz, might be why.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
Set WPA2 and AES on the Orbi router and apply and reboot both router and satellite.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
keung006
Oct 04, 2018Aspirant
I have followed your instruction one by one. It still doesn’t work. But when I the 5.0Gz from 36 to 40,44. The upload is faster, I finish upload within 10mins. But when I upload another movie, the upload speed remain very slow...
- FURRYe38Oct 04, 2018Guru - Experienced User
Interesting that changing channels helps however only for the one upload then slows back down.
I think NG support needs to review this.
- Christian_ROct 04, 2018NETGEAR Employee Retired
keung006 - What FW are you on? Please check if your units are on the latest FW and perform factory reset after the FW update
~Christian
