keung006
Oct 03, 2018Aspirant
RBK40 upload movie on youtube by wifi
The youtube upload speed through is extremely slow, it takes 70minutes for 1GB movie. But the speed test shows that the upload speed is 65Mb/s.
But when I use 4G mobile network to upload the same ...
Oct 04, 2018Guru - Experienced User
Interesting that changing channels helps however only for the one upload then slows back down.
I think NG support needs to review this.
Christian_R
Oct 04, 2018NETGEAR Employee Retired
keung006 - What FW are you on? Please check if your units are on the latest FW and perform factory reset after the FW update
~Christian
