AlmondRoca
Feb 28, 2019Tutor
RBK40 v1.12.0.20 Satellite drops connection to Router
RBK40 satellite not able to keep stable connection to router. This has ocurred on three DIFFERENT RBK40 units; had to return previous two.
Does not matter how close or far the satellite is located ...
Apisto75
Mar 01, 2019Aspirant
Hello!
Is this all the time or after a while? Mine works for a few days then it craps out and both router an satelite needs several reboots to get running again. Then it works for a few days again until I need to repeat the process.
Satelite is about 6 meters away with one thin wall inbetween.
Also check this out:
https://community.netgear.com/t5/Orbi/RBK40-v2-2-1-210-Satellite-drops-internet/m-p/1712892#M53721
