rsquarev1
Feb 26, 2019Tutor
RBK40 v2.2.1.210 Satellite drops internet
My RBK40 was setup more than a month ago and it was updated to latest firmware by that time to 2.2.1.210. Then I had to factory reset my router twice to work properly. Issue is that devicess connecte...
- Apr 08, 2019
Netgear support replaced the satellite with other one. New satellite didnt work plug and play. Had to reconfigure both router and satellite together. But finally it works.
rsquarev1
Feb 26, 2019Tutor
Modem: Centurylink | Actiontec C2000A (on transparent bridge)
Model: RBK40
Mode: Router
Home SqFt: 3500
Distance: Router in Basement and Satellite on Main floor. Distance would be about 20-25ft.
Channels: Auto. I checked thru wifi analytics app and the channels Orbi used and they NOT overloaded by neighbors' routers.
Security options: WPA2-PSK [AES]
Beamforming and MIMO: I tried these once before doing factory reset. But no change in issue.
Feb 26, 2019Guru - Experienced User
Distance between base and satellite maybe too close. try to move the satellite a bit farther out. I would test with just the Orbi base to see if the problem continues.
Try manual channels and enable Beamforming and MIMO.
rsquarev1 wrote:
Model: RBK40
Mode: Router
Home SqFt: 3500
- Chuck_MFeb 26, 2019Mentor
Using your web browser, go into your web gui (probably 192.168.1.1) and add to it /RST_conn_status.htm
The address will look like this:
http://192.168.1.1/RST_conn_status.htm
What are your DNS servers and your lease obtained/expires times?
And while you are in there, please let us know the NTP settings under
http://192.168.1.1/adv_index.htm
I suspect you have the lease renewal issue which has a simple fix.
