rsquarev1
Feb 26, 2019Tutor
RBK40 v2.2.1.210 Satellite drops internet
My RBK40 was setup more than a month ago and it was updated to latest firmware by that time to 2.2.1.210. Then I had to factory reset my router twice to work properly. Issue is that devicess connecte...
- Apr 08, 2019
Netgear support replaced the satellite with other one. New satellite didnt work plug and play. Had to reconfigure both router and satellite together. But finally it works.
gr8sho
Mar 13, 2019Virtuoso
rsquarev1 wrote:
Satellite CPU is now between 13 & 20%. It was over 45 constantly in the past.
Router CPU is pretty stable at 8-15%
Where is this information visible?
rsquarev1
Mar 13, 2019Tutor
orbilogin.net/debug.htm (router)
192.168.1.2/debug.htm (satellite)
IP may be different for your satellite. you can find the ip in attached devices from orbilogin.net/index.htm
- gr8shoMar 13, 2019Virtuososimple page, nice. 14% here under moderate load. Although I have no context at all about how hard the CPU should work in a router.
