rvilata
Mar 24, 2018Aspirant
rbk40 vs rbk20
Already decided to purchase a kit RBK40+satelite, when I was trying to buy through Amazon I noticed that was a new model called RBK20 (on the amazon appeared as "new model"). Then I search on Netgear website and I found it, but without clear differences. The only remarcabable difference is, a part of the phisical dimensions and weight , the number of LAN ports and the flash and RAM memory. RBK20 have less LAN ports and less flash and RAM,.........but may be both parameters are linked..... sounds rasonable that a systems with less LAN ports need less RAM. But I router with only 512Mb RAM sounds not enough....
LAN ports are really not important in my case, but can someone knows if there is other differences more related to performance or speed.
Thanks a lot.
Ricard
Key specs to look for are wireless connection rates and over all home coverage sq footageL
RBR40:
Combined WiFi speed 2,200 Mbps (400 + 866 + 866Mbps) Coverage 4,000 sq ft Dedicated Backhaul 2x2 (866 Mbps) WiFi Technology Tri-band
4GB flash and 512MB RAM
RBR20
Orbi AC2200 Router and AC2200 Satellites (866+866+400Mbps) Coverage 5,000 sq ft Dedicated Backhaul 2x2 WiFi Technology Tri-band Router: 4GB Flash and 512MB RAM
Satellites: 256MB Flash and 512MB RAM each
Seem very similar.
How big is your home sq ft?
I would try the 40 kit first.
- rvilataAspirant
Thanks a lot.
Yes I believe they are very similar. My home is less than 4000 sq ft, two floors. So both systems fits.
The only thing that bothers me is Netgear have two products on portfolio for the same coverage.............
Ya seems like there really trying to squeeze out different products.
I have the RB40 system in my 5000 sqft place. Awesome system.
Let us know what you decide.
