carlobukowski25
Sep 17, 2020Aspirant
RBK40 vs RBK50V vs RBR753
I currently have a RBK40 AC2200 system with 2 satellites in a 2 level ~2,500 SQ ft flat and I am having buffering issues when up to 20 devices are connected on the network with 1 GB Sonic Fiber inter...
Mstrbig
Sep 17, 2020Master
carlobukowski25 wrote:I currently have a RBK40 AC2200 system with 2 satellites in a 2 level ~2,500 SQ ft flat and I am having buffering issues when up to 20 devices are connected on the network with 1 GB Sonic Fiber internet service. It worked fine for our needs pre pandemic, but now that I have multiple people working from home and remote learning, can I upgrade to the RBK50V AC3000 and experience better quality or should I upgrade to the new Wifi 6 RBK753? I don't plan on running up to 40+ devices like the RBK753 states that it can handle and plan to maintain my 20-22 devices (TVs, laptops, smart phones, nest cameras and thermostat, ring doorbell and chime, printers, tablets), but I am wondering if the RBK50V will solve my issues when 20 devices are connected to the network. Thanks.
I assume you have 1 RBR43 system?
How do you have your satellites placed in conjuntion to your router and satellites?
The RBK53 is a more powerful system with more antennas and a faster backhaul. The RBK73 is a super nice system that is even more powerful. However depending on your setup, they may not solve your issue.
If your buffering issues are internet related, it very well can be the ISP having bandwidth issues. Most ISPs are overloaded, due to everyone working at home video conferencing, streaming, VOIP, etc., in addition to their normal bandwidth load. ISP bandwidth is a burstable format. You are paying for 1GB internet, however, the more users online in your area will have an impact on your bandwidth. Fiber is nice because the transfer speeds through the hubs are faster. But it can still only handle so much traffic.
Try these suggestions as they may help:
Go to orbilogin.com
Disable Circle, Armor, Daisy Chaining, Fast Roaming, IPv6 and uncheck 20/40Mhz Coexistence.
Enable WMM, Implicit BeamForming, Mu-MIMO
Set Short preamble mode. Save settings, reboot Orbi.
Also if wired, what cable size was used, as wrong size can cause slow speed.
Also turn off any logs you don't need to reference as well as the traffic meter. They both can steal bandwidth.
carlobukowski25
Yes, the RBK43S from Best Buy 1RBR + 2 RBS40's. The router is located near the front of the house on the top floor close to where the ONT is connected from the exterior. I have one satellite placed halfway down the length of the house from the router on the same floor and the other satellite is placed towards the back of the downstairs approximately the same distance from the second. The overall dimensions of the flat is approximately 58' length by 25' width from the exterior. We don't really use any wifi/internet in the garage portion of the downstairs so the living space would be approximately 2,200 sqft. Some of the wired devices are Cat5 or Cat6 cables. Most of those devices don't seem to experience issues as much as the Wifi enabled devices. Nest Cameras and Smart TVs or ROKU/APPLE TV devices that are not necessary for use when working, I have switched off in the Orbi App so they do not take any WiFi. I will walk through the recommendations you have set below and report back. Thanks.
- MstrbigSep 17, 2020Master
Also change out any Cat5 cable you have and replace with at least Cat5e.
- carlobukowski25Sep 17, 2020Aspirant
Most of my cables are CAT 6, one CAT5e and only CAT5 to a printer I seldom use. I found a CAT 5e cable in the closet and swapped it out.
I also turned off the traffic meter and I don't know where the "logs" are.
- MstrbigSep 18, 2020Master
carlobukowski25 wrote:I also turned off the traffic meter and I don't know where the "logs" are.
orbilogin.com > Advanced > Administration > Logs
