manuel-c23
Oct 01, 2017Star
RBK40 weak backhaul after v2 firmware upgrade
I own an Orbi RBK40 wifi system. My satellite unit is a bit far from the main unit (this is why I'm waiting for the wired backhaul implementation), however I got an intermittent blue/orange statu...
st_shaw
Oct 01, 2017Master
You will need to move your satellite and router, so they are closer together and/or have fewer obstructions between them.
- manuel-c23Oct 01, 2017Star
That's not the point. The point is that the backhaul connection is worse after the v2 firmware upgrade.
Anyway, I can't move them.
- st_shawOct 01, 2017Master
Numerous people have reported that the new firmware reduced their backhaul range. You can wait for Netgear to change the firmware such that the range is extended, which may never happen, or you can move the units. If you do not want to move them, you could try adding an additional satellite in between the existing satellite and router, and using the new daisy-chain feature.
- sguziDec 09, 2017Aspirant
Same issue with the RBS50 & RBR50. they have always worked perfectly either end of the house, now I have upgraded to the firmware the range has now been reduced...... funny that happens to co-inside with the new release of SRK60. what a joke! wont be upgrading or adding a new sat, will just replace the thing - as they will only continue to reduce the range as new products come out.
