manuel-c23
Oct 01, 2017Star
RBK40 weak backhaul after v2 firmware upgrade
I own an Orbi RBK40 wifi system. My satellite unit is a bit far from the main unit (this is why I'm waiting for the wired backhaul implementation), however I got an intermittent blue/orange statu...
manuel-c23
Oct 01, 2017Star
That's not the point. The point is that the backhaul connection is worse after the v2 firmware upgrade.
Anyway, I can't move them.
st_shaw
Oct 01, 2017Master
Numerous people have reported that the new firmware reduced their backhaul range. You can wait for Netgear to change the firmware such that the range is extended, which may never happen, or you can move the units. If you do not want to move them, you could try adding an additional satellite in between the existing satellite and router, and using the new daisy-chain feature.
