wpeace
Apr 30, 2019Aspirant
RBK40 Wired Performance disappointing
Forgive me as I posted this in the wrong forum initially.
I recently installed an Orbi RBK40 in my home and I noticed the ethernet ports on the RBR40 are not achieving anywhere near acceptable ...
Apr 30, 2019Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
What is the Mfr and model# of the ethernet switch if one is in the configuration.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
When speed testing are you testing with a wired PC and using OOklas speed test app or web browser and speed test site while ALL other devices are turned off or disconnected from the orbi system?
Has a factory reset been performed and setup from scratch since v48 was updated?
