tleung927
May 01, 2018Tutor
rbk40 WOL via internet not working
I was use D-Link and asus router before and i can make the WOL working easily (set the reserver IP and port forwarding ) but after i move to new house i need a better range router. So I choose Orbi R...
- May 04, 2018
OMG it's working finally but not by port forward.
I am using router build in VPN + openVPN + tool in windows call wakemeonlan. Everything is working now even though i am not able to make it work on iOS. I try all the WOL app + openVPN on my iphone but nothing works so far. Anyway thanks for you help.
May 02, 2018Guru - Experienced User
I don't use WOL however as a work around, connect up one of the other Mfr routers and use them as your WoL router. Connect up the Orbi router in AP mode and be sure to disable any wifi radios on the other Mfr routers.
What model routers were these other routers?
tleung927
May 02, 2018Tutor
I use tp-link ac3200 and T-Mobile asus router before .unforturnaly , i has sold and return them already so that is not an option for me
